Hi, Acrylon,
I'm a little unclear when you say it keeps looking for the Adagio.ssi file in H:\Softrak\data during the install. The install doesn't look for the adagio.ssi file at all.
The destination directory during the installation should be to the same network drive that all other Adagio modules are installed on (eg. p:\Softrak\RPWIN). This is where the Adagio component of the installation is to be installed.
The report tables drive defaults to the same drive as the your other Adagio modules. It should reflect the drive that the \QRASP folder resides on the server.
If you've moved where the data is being stored (eg. from H to P) and every time you go to create a new report it's looking for the adagio.ssi on H, then it's possible you've set a default Database Source Defaults data directory under File | Options in Crystal. Change this to P. The adagio.ssi file and the zzglob.xxx files are always stored in your data directory (where 'zz' is the 2-character Adagio module identifier and 'xxx' is your 3-character data extension).
