#9773 - 09/05/07 04:05 PM Message Prompt in Order Entry
Acrylon Offline
Everyone at our company is constantly getting the same message prompt in Order Entry. It is as follows: "The order statistics will now be updated, due to postings in ACCPAC Order Entry." It comes up when logging in and what seems at random when the program is open. Although this isn't causing any technical problems, it is becoming a real pain!
Is there anyway to stop this prompt? I'm am pretty sure no one is using ACCPAC anymore. If there is, is there a way to tell who is using it?
Thanks!
Cam
#9774 - 09/05/07 05:56 PM Re: Message Prompt in Order Entry [Re: Acrylon]
Hello Cam,
Someone's using ACCPAC (see Help | Active users) or your multi-user access to Adagio is not set up properly. The message occurs when OrderEntry detects that its internal count of orders, invoices and credit notes does not match the count in the file. The occurs if someone creates or invoices an order in ACCPAC Plus Order Entry. Remove the ACCPAC Plus icon from everyone's desktop.
#9831 - 09/13/07 04:12 PM Re: Message Prompt in Order Entry [Re: Retired_Guy]
Acrylon Offline
ACCPAC Plus has been removed from everyones' computer, yet the problem presists. Could it be possible that there are a few orders in the file that aren't in OE? I need some help diagnosing the source of the problem.
Thanks so much for your help so far!
Cam
#9833 - 09/13/07 05:22 PM Re: Message Prompt in Order Entry [Re: Acrylon]
Hi Cam,
If ACCPAC Plus has been removed from everyone's computers, then either the multi-user access to Adagio has not been set up correctly, or you have opportunistic locking turned on either on the server or one of the workstations. \softrak\system\chksys.exe will check your opportunistic locking settings when run at a workstation and on the server.
#9842 - 09/14/07 10:45 AM Re: Message Prompt in Order Entry [Re: Retired_Guy]
Acrylon Offline
It looks like opportunistic locking is turned on for some workstations.
Here is what chksys says:
======= Checking Special System Configurations ======
-- Checking the following Registry entries (Local_Machine):
... KEY: System\CurrentControlSet\Services\LanmanServer\Parameters
VALUE: EnableOpLocks (=0)
... KEY: System\CurrentControlSet\Services\LanmanWorkStation\Parameters
VALUE: UseOpportunisticLocking (=0)
... KEY: System\CurrentControlSet\Services\MRXSmb\Parameters
VALUE: OplocksDisabled (=1)
What are the risks in turning off opportunistic locking at these locations?
Thanks again!
Cam
#9843 - 09/14/07 11:13 AM Re: Message Prompt in Order Entry [Re: Acrylon]
Hello Cam,
Risks in turning it off?!
It must be off for Adagio (and most other accounting software) to work properly. Current versions of Adagio display a warning as they start if this is not set correctly.
Turn it off and the other problem will disappear.
#9844 - 09/14/07 11:17 AM Re: Message Prompt in Order Entry [Re: Acrylon]
Hi, Cam,
Opportunistic locking should definitely be disabled (turned off)on any workstations running Adagio. According to Microsoft, leaving it enabled can cause database corruption, slower performance, workstation hanging or lockups, etc.
We recommend that opportunistic locking be turned off if you have any workstations using Adagio wherein it isn't already disabled.
Edited by Softrak Support (09/14/07 11:33 AM)
#9845 - 09/14/07 11:30 AM Re: Message Prompt in Order Entry [Re: Softrak Support]
Acrylon Offline
Thanks all,
Here's the million dollar question that is probably elementry to you guys: how do I turn it off?
I know I have to go into the registry some how and change some values, but does this have to be done on everyones computer who is using adagio, or is there a way to do everyone at once?
Thanks!
Cam
#9846 - 09/14/07 12:30 PM Re: Message Prompt in Order Entry [Re: Acrylon]
Hi Cam,
When you run the CHKSYS.EXE utility from a workstation, it gives you the opportunity to turn it off. If you choose no, you won't be asked the question again and the Windows registry must be edited (in the 3 places mentioned in your post above) manually.
As these are Windows registry keys on a workstation, the CHKSYS utility must be run from each workstation that uses Adagio. It cannot be used to disable for all workstations at one time.
#9847 - 09/14/07 01:20 PM Re: Message Prompt in Order Entry [Re: Softrak Support]
Ralph Allan Offline
Tech Supoport:
I thought these values (from Cam's message above) were correct for OpLocks being OFF.
Nonetheless, of course, he needs to check all workstations and the server.
Ralph Allan
Business Computer Centre
Prince George BC Canada
0 registered (), 37 Guests and 3 Spiders online.
14666 Topics
