#7286 - 07/27/06 06:28 PM Default Field in Import
Barb9 Offline
Adagio Prodigy
Loc: Langley
July 27/06
I am doing an import, with Sale Start Dates, and End Dates. I am choosing these fields in the default area, and so the date itself is coming right from the Adagio program. However, when I click the import button, I receive the following error message:
Invalid Data '07/27/2006" for Field called 'Sale Start Date" of record 1
The import will not work. I deleted these default fields, and imported, and it worked fine, however, I then have to manually change all the dates using the edit button in the actual data, which is cumbersome, to say the least. This default field has worked before, quite beautifully. Any ideas??
Thank you.
#7287 - 07/27/06 08:13 PM Re: Default Field in Import
I just tested this and got the exact same error. Hopefully Softrak Tech Support can shed some light on the problem.
#7288 - 07/28/06 11:44 AM Re: Default Field in Import
Hi Barb/Doug,
This is an error we know about, and it seems to only exist for Inventory; other apps I've looked at work OK.
I can tell you that we are working on a service pack for Inventory and I've seen that this issue has been addressed.
In the mean time, you can import the sale date fields - if you are importing from an Excel file, copy/paste cells is very useful in setting this up. Or if this is a CSV file, edit the file with Word and use the Replace All function to insert the sale dates at the end of each record.
0 registered (), 139 Guests and 5 Spiders online.
14578 Topics
