Previous Thread
Next Thread
Print Thread
A
Adagio Groupie
Adagio Groupie
A Offline
In Gridview Is it possible to create a calculated column with concatenated upc numbers for each of my SKU numbers?
I would like them to be separated in a cell with ", " if possible.
Right now I have 17000 sku's that output to 34000 rows and then have to run a script with the exported .csv in google sheets to concatenate and bring it back down to 17000 rows.
eg.
SKU----------Description------Barcodes
123456------Item123-----------65547899, 65541233, 54432166, 15895475
321654------Item321-----------78945556, 45667789, 14785248, 98778845, 45777456
Thank you in Advance
Adrian
Adrain:
Are you creating the GridView off of the CounterSales UPC code table?
Is your GridView outputting a separate record for each UPC code?
With some better details I could provide a more informed answer.
A
Adagio Groupie
Adagio Groupie
A Offline
That's correct Doug. (CounterSales UPC code table)
At the moment I'm outputting 1 row for each UPC which spits out around 34000 rows.
Some of the Item numbers have up to 15 UPC's attached to them, (so they are displayed on 15 rows)
I figure if i could create a new Calculated column that conatenated all of the related UPS for each Item.
Then I could tie each row into my other .CSV export that has 1 row per Item number. (exporting a single CSV instead of two which i combine together in Google Sheets.)
Adrian
Adrian:
Thanks for clarifying how you are using GridView.
What you are currently doing, running GridView to output the data to Google Sheets and then using a script to manipulate the data into what you need, is how I would do this (as an off the top of my head answer).
If I come up with a better answer, I'll let you know.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
1 members (Softrak Support), 79 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,626
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
