#69013 - 12/02/22 09:00 AM Try to add a new Time & Disbursement batch and get
Marshal Offline
Adagio Groupie
Loc: Maryland, USA
When any of our timekeepers try to add a new batch in Time & Disburment Batches we get the following error:
Error adding record to batch control file, record already exists.
We hit ok and get the warning:
Error writing to batch file _____ (and the number here keeps increasing by one every time someone tries to add a batch).
Because of this, no one can add their time in in a new batch - please help.
Thank you
#69014 - 12/02/22 09:20 AM Re: Try to add a new Time & Disbursement batch and get [Re: Marshal]
Hi Marshal:
Did you run a Data Integrity Check? Do a full backup and Run Data integrity. If no errors, it is not the cause.
Batch numbers are only up to 9999, if you haven't done a year end which includes purging the batch status, more likely the numbers are being reused.
Be sure you properly complete the Year End steps.
#69015 - 12/02/22 10:05 AM Re: Try to add a new Time & Disbursement batch and get [Re: Patricia B.]
Marshal Offline
Adagio Groupie
Loc: Maryland, USA
We do a year end every yea. The number that it says it cannot make is 716, then 717 then 718 ...
Also I have done a data integrity check and there are errors but they are because of something to do with a person that does not exist being the primary on a client - this has been this way for a while (over a year).
What else can we try or what additional information can I give you.
Thank you
#69016 - 12/02/22 10:59 AM Re: Try to add a new Time & Disbursement batch and get [Re: Marshal]
Check the batch status Report. The Batch number may have not been saved properly and the batches actually exists.
Try printing and purging the Batch Status report.
#69017 - 12/02/22 11:11 AM Re: Try to add a new Time & Disbursement batch and get [Re: Patricia B.]
Marshal Offline
Adagio Groupie
Loc: Maryland, USA
I do see the batches that it says already exist - Do I choose all 4 types and all 4 statuses when I print the report and then say yes to purge/clear the report?
#69018 - 12/02/22 11:27 AM Re: Try to add a new Time & Disbursement batch and get [Re: Marshal]
I am sorry, I don't see the same options. You might have an older version. You need to contact your Adagio dealer.
#69020 - 12/02/22 02:26 PM Re: Try to add a new Time & Disbursement batch and get [Re: Patricia B.]
Hi Marshal
Fix the errors! Then repeat. It may take a few times to repair all of the errors, and you may not see the ones that matter on the first try.
It's definitely data corruption.
0 registered (), 108 Guests and 10 Spiders online.
14579 Topics
January
