Error 2404:
An error occurred while binding the dictionaries listed in the file which determines the order in which dictionaries are to be bound
Generally means an issue with the dictionaries in ..\ASP\DICT or with the @@@@@@@@.??? file in the data directory.
If you are using QLink to create Financial Reports then you should look at Adagio FX. If you are using QLink to create lists you should look at GridView. Both will work with ACCPAC DOS.
If you are interested in moving into a Windows environment you should look into the Adagio accounting suite.
