#66290 - 06/14/21 09:15 AM Sub-Assemblies on IC
gregs Offline
Adagio Groupie
Loc: ontario
Are sub-assemblies possible on Adagio IC? Everyday I have to manually assemble items on IC that were used as an item for a master item.
Is it not possible, like many other ERPs, that if an item needs to be assembled which, in turn, needed to assemble a Master Item to have it automatically assembled? AKA sub-assemblies?
#66292 - 06/14/21 09:42 AM Re: Sub-Assemblies on IC [Re: gregs]
Eva_Froese Offline
Adagio Expert
Loc: MB
Which modules do you have? Do you have inventory and Bill of Materials (BOM)?
Eva Froese
eva@choicetech.ca
#66293 - 06/14/21 09:51 AM Re: Sub-Assemblies on IC [Re: Eva_Froese]
gregs Offline
Adagio Groupie
Loc: ontario
Yes we have both
#66295 - 06/14/21 10:06 AM Re: Sub-Assemblies on IC [Re: gregs]
The Bill of Materials add-on should do what you are looking for.
#66297 - 06/14/21 11:03 AM Re: Sub-Assemblies on IC [Re: Douglas Dickie]
gregs Offline
Adagio Groupie
Loc: ontario
We have the BOM add on, is there some box I have to click somewhere to activate sub-assemblies?
#66307 - 06/14/21 03:18 PM Re: Sub-Assemblies on IC [Re: gregs]
Eva_Froese Offline
Adagio Expert
Loc: MB
If it is installed, you should see it under the edit menu. Create your Master items and your component items.
Eva Froese
eva@choicetech.ca
#66312 - 06/14/21 05:34 PM Re: Sub-Assemblies on IC [Re: Eva_Froese]
If you would like to build a finished product that is made up of other assemblies (ie sub-assemblies) in one shot, then the answer is no.
You have to first build the sub-assemblies, and then in a separate step build the finished product. Not even Adagio BOM can do this.
#66313 - 06/15/21 12:12 PM Re: Sub-Assemblies on IC [Re: Steve Schwartz]
gregs Offline
Adagio Groupie
Loc: ontario
Thanks Steve, that is what I have experienced.Unfortunatly this is problematic. The master item assembly is triggered when the invoice is generated leaving the sub assembled components in a negative until they are manually handled.
In our business, the sub-assembled pieces are usually pretty simple with some raw material and labour allocated to them.
I have seen other ERPs auto build components of a Master Item that require assembly. Basically the ERP knows that if a component is not in stock and it is an item that requires assembly, then it will build it before satisfying the assembly of the Master item upon the the invoicing.
#66322 - 06/15/21 05:38 PM Re: Sub-Assemblies on IC [Re: gregs]
You have to compare features in a product with other products in the same price range.
But you are correct- automatic multi-level assemblies would be a welcome addition to Adagio.
#66323 - 06/15/21 05:44 PM Re: Sub-Assemblies on IC [Re: Steve Schwartz]
I think the reason I thought the feature was there is because it was for ACCPAC Plus (either that or I'm thinking of some other product).
0 registered (), 217 Guests and 0 Spiders online.
14672 Topics
