Previous Thread
Next Thread
Print Thread
A
Adagio Groupie
Adagio Groupie
A Offline
In Gridview
Instead of searching our records with the following...
RECORDCONTAINS(QUERYSTRING("Enter Search Word"))
Is there any way I could add a second word to narrow the query?
if searching for "red shirt" in the Query I would like to be able to return all items that contain those words but not in any particular order.
"red large shirt", "shirt medium red", "shirt made with red trim", etc.
A
Adagio Groupie
Adagio Groupie
A Offline
There doesn't seem to be a split function to separate the "red" and "shirt".
Hi AGatewood,
There is a function in GridView called MatchAny, where the result is True if any one if a given number of search words (like red or shirt) are found within a target string. But you are correct that you cannot enter one string such as 'red shirt' and each word parses out automatically. You would have to use a separate QueryString function to ask for each word. Something like:
MatchAny({text to search},QueryString("Search word 1"),QueryString("Search word 2"))
There is another similar function called MatchAll, where the result is True only if every search word is found.
I'm guessing the MatchAll behaviour is what you are looking for.
Maybe there is a way to do what you want in combination, such as the QueryString formula being in a calculated column, then a second calculated column calculates text by replacing spaces with commas in order to fit the syntax for MatchAll. Or something like that.
S
S Offline
I have had to do this for a client a couple of years ago.
We achieved this by creating a Gridview Workspace that contains a number of Views.
Briefly, we are performing a search of the Description field of all the detail OE records.
We first perform a search in the first View for a specific Customer for some text, such as “red”, that appears anywhere in the Description field of all the historical OE Invoices.
This generates a second View that filters all the records that contain the word “red” anywhere in the Details line (with other relevant data).
We next click in this second View to further limit the View for another text, such as “large”.
This generates a third View that displays only the records that display both the words “red” and "large".
This is a bit complicated, but if you are performing these kinds of searches on a regular basis, it may be well worth it to create this Workspace.
You can ask your dealer about this, or either you or your dealer can contact me for more information.
Samuel Kopstick
S Kopstick & Associates Inc
Toronto, ON
Hi Adrian:
I would use as filter like this:
and(
FIND({w1} ,{Description},1 ),
FIND({w2} ,{Description},1 )
You can query the words one by one as calculated values or in the filter or you will need to do a formula to split them in two different words.
Adrian:
If you need further assistance please give us a call.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 77 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
