Hi BruceW,
I've moved this to the General Inquiries forum as this is more of a Pre-sales question.
You are correct that Adagio is not compatible with Accpac Plus versions 6.0. The minimum versions of Accpac Plus for compatibility are 6.1A for AR/AP/GL and 6.1B for IC/OE. If you happen to be running these older versions of Accpac and wish to use Adagio, your Adagio consultant can convert the data for you in order for this to work.
Only a couple of chuckles...! ![](images/icons/grin.gif)
