Adagio Fan
Adagio Fan
Posts: 35 |
Hey Team,
I am requesting a feature to be added to the Terms section within Accounts Payable. There are currently 4 different types of due dates within creation of a new Terms. - Specific number of days - End of Next Month - Specific Day of next month - Number of days from a specific day of Month
What we would like to have is a 5th option that is not statically assigned based on a normal value, but rather be a variable that can be configured to be whatever we would like it to be. Not based on criteria such as X amount of days etc. Just be able to specify a due date when a transaction is added. Thank you, Jason
Posts: 3,692 |
HI Jason:
Most of your wish already exists. When you are entering an AP invoice, blank out the Terms code and you can manually enter whatever Due Date you want. The only thing you can't do is to assign a blank Terms codes to a Vendor. But that's not such a bad thing. What Due Date would be calculated from a blank Terms code? Probably today's date. And if the user forgets to change the date, the invoice would due immediately. At least if you start with a Terms code (ie Net 30), the default date is reasonable.
Adagio Fan
Adagio Fan
Posts: 35 |
HI Jason:
Most of your wish already exists. When you are entering an AP invoice, blank out the Terms code and you can manually enter whatever Due Date you want. The only thing you can't do is to assign a blank Terms codes to a Vendor. But that's not such a bad thing. What Due Date would be calculated from a blank Terms code? Probably today's date. And if the user forgets to change the date, the invoice would due immediately. At least if you start with a Terms code (ie Net 30), the default date is reasonable. Bruce, Thanks for your insight, that solved the issue that my controller was having. Thank you, Jason
0 members (),
70
guests, and
2
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
