#63365 - 03/16/20 04:23 PM Payables Workstation Loop Issue - Yes Again
JWH Offline
John Hancock, CPA
Loc: London, ON
We have covered the posts already on the subject and have tried all suggestions but can not get around the workstation loop on Payables V9.3B. It appears "simply" to be that the AdagioV3PDF is not getting installed for whatever reason as it is not listed in the Control Panel for Devices and Printers for the workstation.
Anyway we ran the GetWorkstationInfo application and received the following for this workstation (not sure what we are looking for or what needs to be applied) so thought someone could tell us here:
Adagio Workstation Information [as of 03/16/20 6:18:13 PM]
Run from [P:\SOFTRAK]
User: [Agri-Urban] Logged into [\\AGRI-URBAN-PC]
as Admin. [True] with UAC Enabled [0]
on Computer Name [AGRI-URBAN-PC] Windows Version: [6.1.7601] Processor: [Intel64 Family 6 Model 60 Stepping 3, GenuineIntel]
Adagio Mapped drive: [P:]; UNC: [\\aubiserver\Accounting];
Adagio Payables 9.3B (200301) === Company: [Agri Urban Buildings Inc.]
Wkst Version OK: [True]; Registry [20140734]; {must be >=} Main [20140734]
Report Tables Status: Result is OK: [True]; {Is Eval. version: [False]}
Report Tables drive: CU Registry [P:\]; CU UNC [];
LM Registry []; LM UNC []
Resources: Flags [CIXM9wR3VD]
Web storage Exe: []
PDF Version must update: [True]; Nova File Ver: [8.7.943.0] must be >= SysComponents: [10.2.114.0]
----- Registry Trace: -----
HK_LMx64: [Software\Softland\novaPDF 10] {Default:}; exists: [False];
HK_LMx64: [Software\Softland\novaPDF 8] {Default:}; exists: [True];+Opened;
. .Key: [DriverPath] exists: [True] Value: [C:\Program Files\Softland\novaPDF 8\Driver]
***** Adagio Payables STATUS: WORKSTATION UPDATE REQUIRED. *****
Thanks in advance for any postings.
John Hancock
John W. Hancock & Assoc. Ltd.
#63366 - 03/16/20 04:35 PM Re: Payables Workstation Loop Issue - Yes Again [Re: JWH]
Hello Scott/John:
What happens when you run \Softrak\System\AdagioPDF\AdagioV3PDF.exe?
#63367 - 03/16/20 05:14 PM Re: Payables Workstation Loop Issue - Yes Again [Re: Bruce Gardner]
JWH Offline
John Hancock, CPA
Loc: London, ON
Hi Bruce same thing it "appears" to install but it doesn't. The end result is that the AdagioV3PDF does not show up in the Devices. It just won't install. Unless it is a "rights" issue for whatever reason.
John Hancock
#63369 - 03/16/20 05:21 PM Re: Payables Workstation Loop Issue - Yes Again [Re: JWH]
Vickie_zaam Offline
zaam.ca
Loc: Ontario
Have you tried copying the softrak\system\AdagioPDF folder locally and run the install from there?
Vickie Cegliastro
zaam.ca
613-532-6229
#63370 - 03/16/20 05:43 PM Re: Payables Workstation Loop Issue - Yes Again [Re: Vickie_zaam]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks Vickie no have not tried that thanks for the suggestion will let you know how we make out.
John Hancock
#63371 - 03/16/20 05:47 PM Re: Payables Workstation Loop Issue - Yes Again [Re: JWH]
JWH Offline
John Hancock, CPA
Loc: London, ON
Thanks for the suggestion Vickie but no go.
John Hancock
#63372 - 03/16/20 07:19 PM Re: Payables Workstation Loop Issue - Yes Again [Re: JWH]
Scott:
There's an "AdagioV3PDF_Install.txt" log file - does it show anything significant? Have you tried "Run as Administrator"? Or logging in as the Administrator user? If you look in the Control Panel, does "novaPDF SDK 10 Printer Driver" appear in the list of installed programs? If it does, what if you try to uninstall it and then run the install process again?
I had a similar problem this morning with a client. Installing AdagioV2PDF and AdagioV3PDF solved it so I think you're on the right road.
#63388 - 03/18/20 12:11 PM Re: Payables Workstation Loop Issue - Yes Again [Re: Bruce Gardner]
UAC should be disabled and Run as Administrator with local Administrator rights and it always gets installed properly.
#63406 - 03/19/20 10:51 AM Re: Payables Workstation Loop Issue - Yes Again [Re: Patricia B.]
JWH Offline
John Hancock, CPA
Loc: London, ON
All good now. Thanks for your suggestions. It was simply a Windows 7 issue. As soon as we updated to Windows 10 issue resolved go figure.
John Hancock
0 registered (), 232 Guests and 1 Spider online.
14643 Topics
