Previous Thread
Next Thread
Print Thread
J
JWH
Offline
John Hancock, CPA
John Hancock, CPA
J Offline
We have covered the posts already on the subject and have tried all suggestions but can not get around the workstation loop on Payables V9.3B. It appears "simply" to be that the AdagioV3PDF is not getting installed for whatever reason as it is not listed in the Control Panel for Devices and Printers for the workstation.
Anyway we ran the GetWorkstationInfo application and received the following for this workstation (not sure what we are looking for or what needs to be applied) so thought someone could tell us here:
Adagio Workstation Information [as of 03/16/20 6:18:13 PM]
Run from [P:\SOFTRAK]
User: [Agri-Urban] Logged into [\\AGRI-URBAN-PC]
as Admin. [True] with UAC Enabled [0]
on Computer Name [AGRI-URBAN-PC] Windows Version: [6.1.7601] Processor: [Intel64 Family 6 Model 60 Stepping 3, GenuineIntel]
Adagio Mapped drive: [P:]; UNC: [\\aubiserver\Accounting];
Adagio Payables 9.3B (200301) === Company: [Agri Urban Buildings Inc.]
Wkst Version OK: [True]; Registry [20140734]; {must be >=} Main [20140734]
Report Tables Status: Result is OK: [True]; {Is Eval. version: [False]}
Report Tables drive: CU Registry [P:\]; CU UNC [];
LM Registry []; LM UNC []
Resources: Flags [CIXM9wR3VD]
Web storage Exe: []
PDF Version must update: [True]; Nova File Ver: [8.7.943.0] must be >= SysComponents: [10.2.114.0]
----- Registry Trace: -----
HK_LMx64: [Software\Softland\novaPDF 10] {Default:}; exists: [False];
HK_LMx64: [Software\Softland\novaPDF 8] {Default:}; exists: [True];+Opened;
. .Key: [DriverPath] exists: [True] Value: [C:\Program Files\Softland\novaPDF 8\Driver]
***** Adagio Payables STATUS: WORKSTATION UPDATE REQUIRED. *****
Thanks in advance for any postings.
John Hancock
John W. Hancock & Assoc. Ltd.
B
B Offline
Hello Scott/John:
What happens when you run \Softrak\System\AdagioPDF\AdagioV3PDF.exe?
J
JWH
Offline
John Hancock, CPA
John Hancock, CPA
J Offline
Hi Bruce same thing it "appears" to install but it doesn't. The end result is that the AdagioV3PDF does not show up in the Devices. It just won't install. Unless it is a "rights" issue for whatever reason.
John Hancock
V
zaam.ca
zaam.ca
V Offline
Have you tried copying the softrak\system\AdagioPDF folder locally and run the install from there?
Vickie Cegliastro
zaam.ca
613-532-6229
J
JWH
Offline
John Hancock, CPA
John Hancock, CPA
J Offline
Thanks Vickie no have not tried that thanks for the suggestion will let you know how we make out.
John Hancock
J
JWH
Offline
John Hancock, CPA
John Hancock, CPA
J Offline
Thanks for the suggestion Vickie but no go.
John Hancock
B
B Offline
Scott:
There's an "AdagioV3PDF_Install.txt" log file - does it show anything significant? Have you tried "Run as Administrator"? Or logging in as the Administrator user? If you look in the Control Panel, does "novaPDF SDK 10 Printer Driver" appear in the list of installed programs? If it does, what if you try to uninstall it and then run the install process again?
I had a similar problem this morning with a client. Installing AdagioV2PDF and AdagioV3PDF solved it so I think you're on the right road.
UAC should be disabled and Run as Administrator with local Administrator rights and it always gets installed properly.
J
JWH
Offline
John Hancock, CPA
John Hancock, CPA
J Offline
All good now. Thanks for your suggestions. It was simply a Windows 7 issue. As soon as we updated to Windows 10 issue resolved go figure.
John Hancock
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
