Previous Thread
Next Thread
Print Thread
B
Adagio Fan
Adagio Fan
B Offline
We have just received the License number for the GridviewRW module.
Gridview has been installed on our system for the last number of years.
When I open the Gridview module I can not see where I enter the License number for the GridviewRW.
The "About " screen shows three tabs : "Adagio Gridview", Adagio GridviewRW" and "System Info". The Adagio Gridview shows it is registered, but the Adagio GridviewRW is "not registered".
Any suggestions ?
Thank you
Hi bdgillis,
When the Adagio GridView ReadWrite add-on is installed, the standard registration should appear when you first start the application from the shortcut. It is from here that the Read/Write add-on licencing information is entered.
If your shortcut used for starting GridView does not have /rw as a parameter in the Target, then GridView will be started without the Read/Write add-on being looked for, and thus the registration/licensing process for Read/Write will be bypassed. I suspect that all you need to do is edit your shortcut for using GridView and include /rw in the Target.
Also, you should have two shortcuts for starting GridView, one with the /rw switch in the Target and one without. You should only ever use Read/Write with GridView when you want to make database changes, not just in general usage of GridView, since loading RW affects speed and performance of loading records.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
3 members (Dan_Desautels, Bruce Gardner, Douglas Dickie), 115 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,626
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
