#60029 - 02/11/19 12:27 PM Changing item number segment size
SupportGuy Offline
Loc: Victoria, BC, Canada
Is it possible to increase an item number segment size in the Company Profile?
Thank you,
#60030 - 02/11/19 12:31 PM Re: Changing item number segment size [Re: SupportGuy]
Hi SupportGuy,
Yes it is, but you need the Toolkit for Adagio from Dakota Software to do this, for the Item Format changer. And you still are limited to 4 segments and a 16 character maximum width.
#60031 - 02/11/19 12:33 PM Re: Changing item number segment size [Re: Softrak Support]
SupportGuy Offline
Thank you. We do have toolkit. Any pitfalls I should be aware of? Full backup before hand?
#60032 - 02/11/19 12:35 PM Re: Changing item number segment size [Re: SupportGuy]
Of course make a full backup.
Specific pitfalls would be best left to Dakota or other consultants with knowledge of this particular utility.
#60033 - 02/11/19 01:13 PM Re: Changing item number segment size [Re: Softrak Support]
Joe:
Currently you have IC setup for 2 segments using a total of 10 characters. If all you want to do is add 6 characters to the second segment, its fairly straight forward. If your trying to do something else, like add more characters to the first segment or add a third segment, depending upon what you are trying to accomplish it gets more complex. I'd really need to know what your trying to accomplish before I could answer further.
#60035 - 02/11/19 01:54 PM Re: Changing item number segment size [Re: Douglas Dickie]
SupportGuy Offline
Hi Doug.
Goal: to increase the length of [segment 2. Part No.] from 9 characters to X characters. X in the case is a value > 9 &&<= Max Size.
Joe.
#60048 - 02/12/19 12:25 PM Re: Changing item number segment size [Re: SupportGuy]
Joe:
Toolkit | Edit | Inventory | Item Format change
You can add more characters to the second segment by adding a ?, for each character to add, to the end of the “New item format” field.
I've sent you an example privately.
1 registered (Softrak Support), 178 Guests and 2 Spiders online.
14666 Topics
