Posts: 77 |
Is it possible to increase an item number segment size in the Company Profile?
Thank you,
Posts: 11,746 |
Hi SupportGuy, Yes it is, but you need the Toolkit for Adagio from Dakota Software to do this, for the Item Format changer. And you still are limited to 4 segments and a 16 character maximum width.
Regards, Softrak Tech Support
Posts: 77 |
Thank you. We do have toolkit. Any pitfalls I should be aware of? Full backup before hand?
Posts: 11,746 |
Of course make a full backup. Specific pitfalls would be best left to Dakota or other consultants with knowledge of this particular utility.
Posts: 4,506 |
Joe:
Currently you have IC setup for 2 segments using a total of 10 characters. If all you want to do is add 6 characters to the second segment, its fairly straight forward. If your trying to do something else, like add more characters to the first segment or add a third segment, depending upon what you are trying to accomplish it gets more complex. I'd really need to know what your trying to accomplish before I could answer further.
Posts: 77 |
Hi Doug.
Goal: to increase the length of [segment 2. Part No.] from 9 characters to X characters. X in the case is a value > 9 &&<= Max Size.
Joe.
Posts: 4,506 |
Joe:
Toolkit | Edit | Inventory | Item Format change
You can add more characters to the second segment by adding a ?, for each character to add, to the end of the “New item format” field.
I've sent you an example privately.
0 members (),
136
guests, and
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
