Previous Thread
Next Thread
Print Thread
L
Acctg
Acctg
L Offline
HI,
In the invoicing module in an open batch I resorted the invoices by invoice number after someone had sorted by customer name. While it was resorting the system seemed to have stopped working so I close the module, but in doing so I lost invoices. I did a check integrity, there were errors so I click for a rebuild (backup), I did this twice. Once this was done the missing invoices were not back in the batch. When I then verified if the batch balanced I noticed that some invoices didn't have the correct amount and item descriptions, Ex. Inv. # 42864 original amount $ 1,803.22 new amount $ 5,501.55, inv.#42907 original amount $ 438.69 new amount $ 176.32. Would you have an idea what could of happened and how this can be fixed.
Thanks !
How did you close the module? If you used Task Manager and "End Task" while Adagio Invoices was shuffling your documents into a different sequence, the files are likely damaged beyond repair.
B
Adagio Ace
Adagio Ace
B Offline
Lynn, je t'appelerai pour essayer de trouuver une solution pour ton problème.
Brian Puddington
Geneva Financial Systems
Montreal
Depuis quand on a commencer de communiquer en Francais sur ce platform?
If I have a client with the same issue I’d like to be able to read the forum for answers also!
S’il vous plait Brian, communiquer en anglais ici.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 77 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
