#57981 - 07/05/18 07:40 PM I need the AdagioV2PDF printer
Fong Offline
Adagio Ace
The bath file ‘ReinstallAdagioPDFx64.bat only reinstalled the AdagioPDF printer for me. But.
AdagioPDF printer works with Ledger (9.3A); Payables (9.3A) & Purchase Order (9.3A).
But ePrint is not working for:
OE (9.3A), IC (9.2A) and AR (9.2A).
These modules are looking for the AdagioV2PDF printer.
Please help.
System is Window 10 Pro.
#57982 - 07/06/18 11:24 AM Re: I need the AdagioV2PDF printer [Re: Fong]
Hi Fong,
When running AdagioV2PDF.EXE, it has to be done with 'Run as Administrator'.
I believe a similar scenario was asked last year in a different topic, where Run as Administrator was the solution.
#57985 - 07/06/18 12:31 PM Re: I need the AdagioV2PDF printer [Re: Softrak Support]
Fong Offline
Adagio Ace
Thank you for the reply. I did read that topic you mentioned. Yes I did run the AdagioV2PDF.exe as Administrator. I saw the install wizard on screen but at the end no AdagioV2PDF printer show up in Devices & Printers.
We fresh installed all our Adagio modules last month. All others windows 7 workstations are working fine with ePrint. Only one new workstation (Windows 10 Pro) we added last week have this problem.
Should I contact my Adagio consultant or my IT person?
Thank you for your help.
#57986 - 07/06/18 01:29 PM Re: I need the AdagioV2PDF printer [Re: Fong]
Fong Offline
Adagio Ace
After I ran the AdagioV2PDF.exe, 3 components relate to the AdagioV2PDF is re-installed.
No Adagio Accounting PDF Printer in Control Panel, Programs and Features.
How do I get this Adagio Accounting PDF Printer back?
#57987 - 07/06/18 02:48 PM Re: I need the AdagioV2PDF printer [Re: Fong]
Hi, Fong,
Probably best to contact your Adagio consultant about this one. It'll probably be faster than trying to go back and forth over the forum.
#57992 - 07/08/18 06:43 PM Re: I need the AdagioV2PDF printer [Re: Softrak Support]
Fong Offline
Adagio Ace
My Adagio consultant is looking for a solution. Can Softrak support help?
