Posts: 1,247 |
I used to be able to select multiple batches and do a "Listing" to print them all in one shot. Now when I select more than one batch, "Listing" becomes greyed out. Is there a setting somewhere to change it so that I can print multiple batches in Ledger again?
Posts: 3,692 |
Hi Susan:
I can multi-select a number of batches and the "List" button doesn't get greyed out as long as they are in sequence (contiguous). I'm using Ledger 9.3A (2018-04-22). I just checked 9.2B and it had the same behaviour.
Posts: 11,746 |
Hi Susan,
Is your batch list sorted by Batch number or Description? If sorted by Description, then you will see the Listing button disabled when multi-selected batches because there is no guarantee that the batch numbers will be consecutive.
Regards, Softrak Tech Support
Posts: 1,247 |
Okay, that's the problem! Somehow it was changed to sort by description. I've changed it back to batch numbers, so it should be good now. I'll check tomorrow when I have more batches. Thank-you!
0 members (),
77
guests, and
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
