#57076 - 04/06/18 06:25 AM ePrint settings for Adagio PO module
Vlad Maksymiv Offline
Adagio ADP
Loc: Toronto, Canada
Hello Support,
What exactly setting (all) inside Adagio PO module allow Purchase Order print form to be created and saved as PDF file on the print event ?
Thank you
Vlad Maksymiv
www.lenmax.com
#57080 - 04/06/18 06:46 AM Re: ePrint settings for Adagio PO module [Re: Vlad Maksymiv]
Dan_Desautels Offline
Loc: Thunder Bay, ON, Canada
Hi Vlad,
In the Company Profile under Reports/specs select the option "Archive PDF Vendor Copy". This is the most important one since it will be linked to the transaction.
If you want an additional Accounting Copies with a different spec for internal purposes, you can select those options under Company Profile "PDF/Excel Options". Those would save under the Reports/Audit directory.
Edited by Dan_Desautels (04/06/18 06:49 AM)
Dan Desautels
DezTek Solutions Inc.
Thunder Bay, ON
#57205 - 04/13/18 12:07 PM Re: ePrint settings for Adagio PO module [Re: Dan_Desautels]
Adagio ADP
Hello Dan,
I tried this and it does not work. Attachments\POs folder is empty no matter how I try
What else can be missing ?
Vlad Maksymiv
www.lenmax.com
#57207 - 04/13/18 12:16 PM Re: ePrint settings for Adagio PO module [Re: Vlad Maksymiv]
Adagio ADP
Why Softrak Support does not answer this post ?
How else can I request support on this issue ?
Vlad Maksymiv
www.lenmax.com
#57208 - 04/13/18 12:36 PM Re: ePrint settings for Adagio PO module [Re: Vlad Maksymiv]
The Archived Vendor Copy does not save in the Attachments\PO folder. It saves in the SoftPDF folder so that the AP Vendor transaction record can have a PDF viewer button. Are you trying to email the PO to the client? If so, you need to use the Email Button in the PO print dialogue box. You don't need anything in the Attachments folder unless you want to attach additional documents.
Either printing or emailing will store the PDF for later viewing.
Dan Desautels
Thunder Bay, ON
#57209 - 04/13/18 12:48 PM Re: ePrint settings for Adagio PO module [Re: Dan_Desautels]
Adagio ADP
SoftPDF is empty too
I am trying to find the new file on disk , nothing is created
All I want is to get PDF of PO on print event for e-storage
Vlad Maksymiv
www.lenmax.com
#57210 - 04/13/18 12:51 PM Re: ePrint settings for Adagio PO module [Re: Vlad Maksymiv]
What version of PO are you running? Is DocStore installed and enabled?
As a Reseller, you can phone for support.
#57211 - 04/13/18 01:28 PM Re: ePrint settings for Adagio PO module [Re: Retired_Guy]
Adagio ADP
Hello Andrew,
9.2B (161129)
No DocStore on this site
Vlad Maksymiv
www.lenmax.com
#57214 - 04/13/18 02:55 PM Re: ePrint settings for Adagio PO module [Re: Vlad Maksymiv]
Is ePrint installed and enabled?
0 registered (), 143 Guests and 0 Spiders online.
14538 Topics
