Adagio ADP
Adagio ADP
Posts: 199 |
Hello Support,
What exactly setting (all) inside Adagio PO module allow Purchase Order print form to be created and saved as PDF file on the print event ?
Thank you
Posts: 1,209 |
Hi Vlad,
In the Company Profile under Reports/specs select the option "Archive PDF Vendor Copy". This is the most important one since it will be linked to the transaction.
If you want an additional Accounting Copies with a different spec for internal purposes, you can select those options under Company Profile "PDF/Excel Options". Those would save under the Reports/Audit directory.
Adagio ADP
Adagio ADP
Posts: 199 |
Hello Dan,
I tried this and it does not work. Attachments\POs folder is empty no matter how I try What else can be missing ?
Adagio ADP
Adagio ADP
Posts: 199 |
Why Softrak Support does not answer this post ? How else can I request support on this issue ?
Posts: 1,209 |
The Archived Vendor Copy does not save in the Attachments\PO folder. It saves in the SoftPDF folder so that the AP Vendor transaction record can have a PDF viewer button. Are you trying to email the PO to the client? If so, you need to use the Email Button in the PO print dialogue box. You don't need anything in the Attachments folder unless you want to attach additional documents.
Either printing or emailing will store the PDF for later viewing.
Adagio ADP
Adagio ADP
Posts: 199 |
SoftPDF is empty too I am trying to find the new file on disk , nothing is created All I want is to get PDF of PO on print event for e-storage
Posts: 10,504 |
What version of PO are you running? Is DocStore installed and enabled?
As a Reseller, you can phone for support.
Adagio ADP
Adagio ADP
Posts: 199 |
Hello Andrew,
9.2B (161129) No DocStore on this site
Posts: 10,504 |
Is ePrint installed and enabled?
0 members (),
70
guests, and
2
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
