Posts: 10,504 |
Adagio PurchaseOrders 9.3A (170821) is now available. This Upgrade offers the following improvements: - Import and Export Event Budgets. Import allows you to overwrite existing budgets.
- ExcelDirect Print available for Outstanding Purchase Orders and Outstanding Receipt Invoice List.
- Invoice/Adjustment Clearing Account used when there are adjustments to item cost from multiple vendors using different Vendor Document dates.
- Requisition Approval User, Date and Time fields on grids, custom reports and GridView views.
- The Adagio Login dialog permits browsing to a UNC. The Create database button is hidden unless “/C” is included on the command line. New databases are created with the extension “ADB” or the extension used by existing modules in the selected Folder.
- A “Backup” button has been added to the Adagio Toolbar. Backup Options select whether the button saves the module data, related data or the entire database and whether exclusive access is required for the backup to proceed. The backup now includes the Automation Batch Folder.
- Backup options enable automatic or prompted backups prior to performing any critical function such as batch posting or period end functions. You can choose the number of backups that will be saved.
- Only a single instance of Calculator will be launched when the Calculator button is clicked.
- User preferences have been added to control the behaviour of double clicking in a Dialog field. You can also choose to apply banding to those grids that do not display Styles and choose a date format to use in the Adagio Grid. Telephone numbers are now formatted in the Grid according to the Company profile option.
- Installs \Softrak\System\AdagioLauncher.EXE and associates the application with “ADB”, “SAM” and “AMC” extensions. AdagioLauncher will automatically launch the correct Adagio module if an Adagio file is double clicked in a Folder. The user will be prompted to log in.
- Compatible with future release of Adagio DocStore.
- Compatible with future release of Adagio OrderEntry 9.3A
Announcements have been sent!
0 members (),
136
guests, and
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
