#50744 - 08/11/16 09:12 AM GridView error ...'@L92APIN' with the wildcard...
Accounting Offline
Adagio Fan
Loc: Prince George
Using GridView 9.2B and this error has been happening for quite some time and I just ignore it (by hitting OK) but I'd like to fix it permanently. It happened after a GL update some time ago.
Error reads:
The data set '@L92APIN' with the wildcard '*-All' does not exist!
These are the 4 fields I use (with filters):
Fiscal Year
Trx Acct
Trx Dept
Amount
Does anyone have any suggestions?
#50754 - 08/12/16 08:44 AM Re: GridView error ...'@L92APIN' with the wildcard... [Re: Accounting]
It sounds like you're using the G/L Posted Transactions table for the view. @L92APIN is a reference to this table. it may be that the correct dictionary doesn't exist in your Softrak\dict folder. This Softrak folder would also be the one you're running Gridview from.
It could also be that you're using this table and pointing at an older dataset (i.e. one that would use an older @L table).
You might want to contact your Adagio consultant who can help you troubleshoot this issue.
0 registered (), 121 Guests and 3 Spiders online.
14599 Topics
