#50159 - 06/09/16 12:33 PM Adagio Calendar
spence101 Offline
Stranger
Loc: British Columbia, Canada
Adagio Ledger/BankRec/AR/AP/Invoices: I used to be able to tab onto an Adagio Calendar window and type in the number 9, resulting in the calendar automatically selecting June 9, 2016. For the past two months Adagio no longer allows this short cut feature which lets me select a calendar date quickly. An error message shows up, “Please enter a valid date”.
Since the calendar short cut feature stopped working, I noticed it changed the date format on the detail lines on the Adagio Invoices. Dates on the detail lines used to appear as 06/09/2016, now it appears as 06-09-2016.
Q. Is there a way to change system settings to get short cut calendar feature back? Also, since the short cut calendar feature stopped working, is that what changed the detail line date format on Adagio Invoices?
#50160 - 06/09/16 12:44 PM Re: Adagio Calendar [Re: spence101]
Hello Spence101,
This feature is still working but my Short date setting is M/d/yyyy.
Have you changed the date format in Regional settings? What is your Short date format?
#50162 - 06/09/16 12:58 PM Re: Adagio Calendar [Re: Softrak Support]
spence101 Offline
Stranger
I didn't make any changes.
If I go to File --> User Preferences --> Report Options --> The date formats read as follows:
Date format (Header/Footer) MMM dd yyyy
Date format (Detail) MM/dd/yyyy
Is that the problem area?
#50163 - 06/09/16 01:27 PM Re: Adagio Calendar [Re: spence101]
Support was referring to your Windows settings - from the Control Panel.
#50164 - 06/09/16 02:04 PM Re: Adagio Calendar [Re: Retired_Guy]
spence101 Offline
Stranger
Thanks Softrak Teck Support and Andrew
Problem solved
0 registered (), 289 Guests and 0 Spiders online.
14636 Topics
