#47602 - 10/16/15 12:17 PM Error 1342
Tam Offline
New Guy
Loc: BC
Good day.
In the middle of posting a batch, my general ledger module froze and indicated 'not responding'. I can now go back into the module and view but if I try and create a batch, I am told 'error 1342 occurred when attempting to append record to batch control file'; a data integrity check stalls at 'checking batch control files'; and I cannot do a back up.
This problem exists only in one company, I am still able to operate in the general ledger module in other companies.
Thank you.
#47605 - 10/16/15 12:24 PM Re: Error 1342 [Re: Tam]
Hi Tam,
That error is indicative of corrupted data. If you cannot run a backup, you may have to reboot to release a file - which may have been the cause of the error in the first place.
#47607 - 10/16/15 12:29 PM Re: Error 1342 [Re: Softrak Support]
Tam Offline
New Guy
Loc: BC
Thank you for the quick response.
I have indeed rebooted....to no avail.
#47609 - 10/16/15 01:42 PM Re: Error 1342 [Re: Tam]
Tam:
Looks like you will need to restore a backup from prior to the crash or get the database repaired. Your Adagio consultant should be able to assist you with either task.
#47610 - 10/16/15 02:04 PM Re: Error 1342 [Re: Douglas Dickie]
Tam Offline
New Guy
Loc: BC
Thank you. Hopefully we can also determine what would have caused something like this to happen.
#47612 - 10/16/15 02:15 PM Re: Error 1342 [Re: Douglas Dickie]
Tam Offline
New Guy
Loc: BC
#47616 - 10/16/15 04:02 PM Re: Error 1342 [Re: Tam]
Tam:
Determining the cause will be much harder. In the 20 years that I have been doing this its almost always not Adagio and with the exception of the obvious (power failure and computer past its best before date) the failure has to occur a couple of times before you can figure out what is going wrong.
If your workstation or server is more than 4 years old its time to replace it.
0 registered (), 48 Guests and 2 Spiders online.
14655 Topics
