Previous Thread
Next Thread
Print Thread
#47602 10/16/15 04:17 PM
T
Tam
Offline
New Guy
New Guy
T Offline
Good day.
In the middle of posting a batch, my general ledger module froze and indicated 'not responding'. I can now go back into the module and view but if I try and create a batch, I am told 'error 1342 occurred when attempting to append record to batch control file'; a data integrity check stalls at 'checking batch control files'; and I cannot do a back up.
This problem exists only in one company, I am still able to operate in the general ledger module in other companies.
Thank you.
Tam #47605 10/16/15 04:24 PM
Hi Tam,
That error is indicative of corrupted data. If you cannot run a backup, you may have to reboot to release a file - which may have been the cause of the error in the first place.
T
Tam
Offline
New Guy
New Guy
T Offline
Thank you for the quick response.
I have indeed rebooted....to no avail.
Tam #47609 10/16/15 05:42 PM
Tam:
Looks like you will need to restore a backup from prior to the crash or get the database repaired. Your Adagio consultant should be able to assist you with either task.
T
Tam
Offline
New Guy
New Guy
T Offline
Thank you. Hopefully we can also determine what would have caused something like this to happen.
T
Tam
Offline
New Guy
New Guy
T Offline
Tam #47616 10/16/15 08:02 PM
Tam:
Determining the cause will be much harder. In the 20 years that I have been doing this its almost always not Adagio and with the exception of the obvious (power failure and computer past its best before date) the failure has to occur a couple of times before you can figure out what is going wrong.
If your workstation or server is more than 4 years old its time to replace it.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 136 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
