#41659 - 05/23/14 11:36 AM Financial Reporter - Department Ranges
Scott Offline
Stranger
First time posting!
Is it possible in the financial reporter to create a department range without including some of the departments?
For example, I have departments 20 - 27 but only want a range excluding department 21.
Thanks in advance for any helpful advice!
Scott
#41660 - 05/23/14 12:08 PM Re: Financial Reporter - Department Ranges [Re: Scott]
Hi Scott
Department ranges must be contiguous. You can also use masks, such as ?2 for departments 12, 22, 32, 42, etc. A mask won't work in your scenario.
It's possible to do what you want but it has to be hard-coded into the statement spec, and is more complicated to explain. If you want an explanation, let me know.
#41693 - 05/27/14 02:02 PM Re: Financial Reporter - Department Ranges [Re: Steve Schwartz]
Using RNGMERGE you can specify the departments you want on a cell as you do with the accounts such as:
B8 = '20,22,27
E20=GLAMT(E$9,RNGMERGE($B20,STRCAT("-",$B$8)))
0 registered (), 242 Guests and 2 Spiders online.
14673 Topics
