Previous Thread
Next Thread
Print Thread
C
Casual
Casual
C Offline
Good Afternoon,
I have finally had a moment to go ahead and close out my prior year however, now in my accounts payable module it will not let me start a new batch... I am assuming that the two incidents are related but can be sure.
There is also a 0.00 batch that appeared as batch #0 that I am unable to delete.
The error that I receive is:
"Error adding record to Payables Batch Control, record already exists"
I then select OK as my only option and then I get another error that says:
"Error writing to the batch"
I am not sure how to fix this, Please advise
Hi Christine,
It sounds like the batch control file is corrupted - there should never be a 'batch zero' record there and this is likely preventing new batches from being created.
Ensure you have a data backup you can restore from, and run a data integrity check to see if this error is found. If so, you can try to Rebuild this error. If the error is not resolved, you would have to contact your Adagio consultant for more in-depth assistance.
If by closing a prior year you mean that you closed a fiscal year in Adagio Ledger, then this would not have caused a problem in your Payables data. If you performed Year End in Payables, then this affects the batch control file by resetting the next batch to 1. We are not aware of any program problems in not doing this correctly, provided that the data integrity was clean prior to running Year End.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 77 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
