Previous Thread
Next Thread
Print Thread
#40998 04/07/14 05:17 PM
S
S Offline
I was attempting to launch A/P, and I received the following message: All Adagio Lanpak licenses (2) are in use. This application cannot be started.
We have a 5 and 2 pack, and when I click Help->Active Users there are only 6 seats in use, and only one of those is A/P, when viewed from O/E.
Any recommended steps to resolved this?
Thank you,
Joe.
SupportGuy #41001 04/07/14 05:51 PM
L
Adagio Padawan
Adagio Padawan
L Offline
Hi Joe,
Have you or your consultant installed upgrades recently?
It might be a case of whenever your last upgrades were done only the 2 Lanpak was upgraded and not both the 2 Lanpak and the 5 Lanpak. Since you have bought them individually you (or your consultant) will need to do the upgrade twice. A quick way to check this is to run the Chksys Utility under the X:\Softrak\System folder. With X being the drive that Softrak is installed on. Be sure to right click on the icon and run it as the Administrator. Once you are on the Adagio System Status Window there is a button in the centre at the bottom of the window called Check Lanpak Status. When you run this function it will tell you how many Lanpak you have installed and what version they are.
If you have installed upgrades recently and all of your Lanpaks are not at 9.0E this would be why you are unable to access AP.
If this is the case you will need to run the Lanpak upgrade again and upgrade your 5 Lanpak.
Also be aware that you get a 'free' Lanpak with each module that you purchase, but that one is module specific. Meaning that if you have GL, AR, AP, BR you can have one user in each of those modules open on their screen with the rest of your users sharing the other 7 licenses (windows). So if the users at your office normally stick to using one or two modules this is why you haven't run into this problem sooner.
Lauren
Lauren Stief
Adagio Solutions and Support
1-800-540-3164
Lauren Stief #41003 04/07/14 06:01 PM
S
S Offline
And, that was it. Thanks for your help.
SupportGuy #41025 04/08/14 11:34 AM
L
Adagio Padawan
Adagio Padawan
L Offline
No problem, glad you have it all sorted out!
Lauren Stief
1-800-540-3164
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 136 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
