#39483 - 12/06/13 01:29 PM Consolidated Report Per Period
Marianne Offline
Accounts Payable
Loc: Surrey, BC Canada
I just want to know on how to create a consolidated report by picking up specific periods. For example, I want a consolidated report for January to June only. I know how to do Departmental report, but I couldn't find how to pick specific periods.
#39484 - 12/06/13 01:42 PM Re: Consolidated Report Per Period [Re: Marianne]
Hi Harpo
Assuming your fiscal year has a calendar year end, then in order to print Jan thru Jun, you will need to enter [1]S in the .CS row in the appropriate column ([1]S translates as the first half of the year).
You should watch the webinar on financial statement design in order to understand the difference between selecting a different period/year, and changing the contents of a column.
#39485 - 12/06/13 01:56 PM Re: Consolidated Report Per Period [Re: Steve Schwartz]
Marianne Offline
Accounts Payable
Thank you for your reply. I will definitely watch the video first, then get back to here when I find something confusing.
#39610 - 12/18/13 10:57 AM Re: Consolidated Report Per Period [Re: Marianne]
Marianne Offline
Accounts Payable
I'm having hard time figuring out how to get a report using Calendar year (Jan-Dec)when our Financial Reporter is set to Fiscal Year, Oct-Sep. Any help? Thanks.
#39613 - 12/18/13 11:09 AM Re: Consolidated Report Per Period [Re: Marianne]
The "GL!12MonthRollingNet.sam" statement in the sample data might be useful in getting you where you are trying to go.
Use File | Import spec and retrieve the statement from the \Softrak\Ledger\Samdata Folder. You'll need to make adjustments to the account ranges of course.
#39615 - 12/18/13 11:25 AM Re: Consolidated Report Per Period [Re: Retired_Guy]
Marianne Offline
Accounts Payable
Our Financial Reporter has been setup to print only the reports per Department including Consolidated per single period (for instance January Income Statement). I don't know how to make a report from scratch. I also know how to create department ranges where it consolidate departments I selected. I hope there is a period ranges because that is the one I am thinking on how to do this. I will study the
GL!12MonthRollingNet.Sam. Thank you!
#39616 - 12/18/13 01:03 PM Re: Consolidated Report Per Period [Re: Marianne]
Marianne Offline
Accounts Payable
Woohooo.... I was able to figure this out. I just used the formula from GL!12MonthRollingNet.Sam and copied all the accounts from our financial statement. Thanks for the tip! smile
1 registered (rah), 37 Guests and 3 Spiders online.
14668 Topics
