Previous Thread
Next Thread
Print Thread
If you choose the wrong customer on an order, is there any way to change it to the correct customer invoicing? If so, is there a section where access can be turned on?
Waterloo Guy
Waterloo Guy
Hi Heather,
You can change the customer on an order to the correct customer, as long as you have not saved the order. If saved, then you can copy the original order to the correct customer, and check off the appropriate boxes to apply the correct customer pricing with item pricing and information (for the correct customer). Then delete the originating order.
If you have not saved and wish to change to the correct customer, then if your OE template is enabled to allow you to edit price lists and customer type (which we would normally recommend), then you could revise the price list and customer type on the order header, but would still need to revise the pricing on the detail lines already entered. If you have a large number of lines already entered or cannot revise pricelist details, just save and copy the order as noted in the wrong customer (first) scenario, and check off the appropriate boxes to update to item pricing and information. Then delete the originating order.
Best,
Brian
Brian Stief,CPA,CA
800.540.3164
Thanks for your response.
Could this example be kept in mind for future updates, so that a person does have access to change the customer on an order. I can understand if the order is already invoiced, but not if the order is only saved. It would be nice to have this function available because in our line of business our customers have very similar names or more than one account.
Thanks and have a great day!!!!!
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 71 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
