Previous Thread
Next Thread
Print Thread
Ledger 9.1a(130423)-Add Accounts
Client chooses add account and the program freezes and user has to End Task.
Looking for ideas for solution.
Any other reports of this?
David
B
B Online: Content
Hi David:
What does Data Integrity say? What happens if they try the same function in sample data? If they have more than 1 computer using Adagio, are the symptoms the same on all computers?
Single user system on 1 computer. Data integrity reports clean. System Status reports no errors. We have not tried the sample data at this point.
View and Edit also freeze the application.
David
Hello David,
Is the "Add account" form opening on another (not visible) monitor? Try setting Window | Original sizes in the application and see if that fixes the problem.
Does it freeze for you on your computer? If so, please send me a ZIP of the data, either via email or http://www.softrak.com/dbr marked to my attention.
Also, you might try installing yesterday's Service Pack and see if that changes things, although there is nothing mentioned in the Release Note about this kind of issue.
Last edited by Andrew Bates; 07/26/13 01:02 PM. Reason: Added Original sizes suggestion.
Data works fine on my laptop with the Service Pack from last nite.
Client installed the Service Pack and Window | Original Sizes was set.
Client is still unable to Add/Edit/or View account in GL with company data or sample data.
David
Broken hardware. Try another computer.
C
Adagio
Adagio
C Offline
David,
From: http://www.softrak.com/ubbthreads/ubbthreads.php/topics/37544/Edit_Accounts_function#Post37544
When you're on the Edit Accounts window, can you access the Column Editor (double click on the column headings row in the grid)and change the 'Active records only' setting? If it is currently enabled, disable it and vice versa. After, close out of the Edit Accounts window and then reopen it.
Chris McDonell
Softrak Systems Inc.
Resolution:
Use of 'Enter'key proved program had not crashed only window with focus was not visible (off the screen).
Used Alt-spacebar M then the arrow keys to find window with focus and move it back into viewable area.
David
As suggested on the morning of the 26th.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
3 members (Patricia B., Softrak Support, Warren Karges), 148 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,627
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
