#33366 - 09/25/12 08:58 AM Adagio's PDF primary printer
MaRiA Offline
New Guy
Loc: Ottawa
My GL was set up to AdagioPDF as a primary printer, so i dont have problem printing the reports as PDF's.
My AP, AR, and Invoices are not the same as the GL PDF printer set up, so each time i print my report, i had to change my printer to AdagioPDF.
Is there a way fixing this problem?
thanks!
#33367 - 09/25/12 09:15 AM Re: Adagio's PDF primary printer [Re: MaRiA]
Hi Maria,
What versions of AR, AP and Invoices are you using?
All default printers are set in Adagio from the File menu and Workstation Options. If you are running an older version of Adagio, this would be in File / Options (if you don't see a Workstation Options choice). Try setting the default printer in AP, AR and IN.
The default printer is saved in the Windows Registry, which means you need enough workstation rights to save in the registry. GL is no different than the other apps, but something to consider if you are trying to change the default printer and it isn't being saved as expected.
#33368 - 09/25/12 10:10 AM Re: Adagio's PDF primary printer [Re: Softrak Support]
MaRiA Offline
New Guy
Loc: Ottawa
thank you! I got it!
0 registered (), 330 Guests and 2 Spiders online.
14666 Topics
