Page 1 of 4 1 2 3 4 >
#25146 - 11/30/10 01:11 PM Invoicing hundreds of orders at once
Nick Sciabica Offline
Loc: Modesto, CA 95350
I have finally begun importing my orders from our web system into Order Entry. Aside from the back-order issue (I need to ensure EVERYTHING is in in stock when importing), it seems to work very well.
QUESTION: I now have a few hundred orders that require invoicing. Is there a way to invoice them as a batch?
#25148 - 11/30/10 05:30 PM Re: Invoicing hundreds of orders at once [Re: Nick Sciabica]
No.
I have tried using Automation Anywhere, but it took about a minute per order, required everyone to be out of OrderEntry while running, and was just plain old finnicky.
It would have been better, had you asked earlier, to import your invoices into Adagio Invoices, which is also integrated with Receivables, Inventory and SalesAnalysis.
#25149 - 11/30/10 05:41 PM Re: Invoicing hundreds of orders at once [Re: Steve Schwartz]
BAMPH Offline
Paradise is perspective
Loc: Christ Church, BARBADOS
Unfortuneately, it won't help you now, but I made a suggestion for an "Auto Invoice" feature to be added to OE for just the type of scenario you are describing. At this point, I don't know if the suggestion is being seriously condidered but if enough people see the need, it just might.
Pete
Peter Banfield
BAMPH Consulting Services
Barbados
#25151 - 11/30/10 06:20 PM Re: Invoicing hundreds of orders at once [Re: BAMPH]
Hi Pete,
But we already have that function - it's called Adagio Invoices.
#25157 - 12/01/10 11:25 AM Re: Invoicing hundreds of orders at once [Re: Retired_Guy]
As Andrew said one option would be to just use Adaiop invoice. The only reason for using Order Entry is to track back orders.
We have done extensive testing with Automation Anywhere and have not found the speed issue that Steve reports. The problem for Automation Anywhere is how to identify the orders to invoice?
#25159 - 12/01/10 12:37 PM Re: Invoicing hundreds of orders at once [Re: Douglas Dickie]
Hi Doug
Hey, I mentioned Adagio Invoices first, not Andrew wink
The reason for the speed issue I experienced with Automation Anywhere is that it has to cater to the slowest machine on the system, which means building in pauses while screens refresh.
As for identifying orders to invoice, that one's easy, with the use of GridView to create a one column report which can be saved as a CSV file. Of course, you would need GridView.
#25161 - 12/01/10 12:41 PM Re: Invoicing hundreds of orders at once [Re: Steve Schwartz]
Why would you be runing a macro to invoice imported orders on more than a single machine (hopefully your fastest one at that)?
#25178 - 12/02/10 05:10 AM Re: Invoicing hundreds of orders at once [Re: Retired_Guy]
Why would anyone create a macro that will fail on all machines but the fastest one? That's like asking for trouble, under the theory that anything that users can do to mess things up, they will.
#25196 - 12/02/10 03:15 PM Re: Invoicing hundreds of orders at once [Re: Steve Schwartz]
Steve's right, you have to create the macro to work on the slowest machine because you never know where the end user might want to run the macro from. Having said that we would expect that clients are running our minimum hardware standard.
#25202 - 12/02/10 06:10 PM Re: Invoicing hundreds of orders at once [Re: Nick Sciabica]
In all this chit chat, we forgot to ask:
Are these really orders, or have you already taken the money and shipped the goods? Could the items be back ordered?
0 registered (), 356 Guests and 0 Spiders online.
14627 Topics
