#28356 - 08/11/11 01:03 PM OE 8.1D (2011.03.16) Credit notes issue
Fong Offline
Adagio Ace
We upgraded to OE 8.1D(2011.03.16) over the weekend. Now our cost has the mentioned problem below. This has not been fixed for credit notes going forward either.
• When issuing a credit note against a previous invoice and returning a different quantity of items to inventory than were on the original invoice, an incorrect extended cost for the items was calculated. This has been fixed for credit notes going forward. Items returned on Credit Notes created in OrderEntry 8.1D (2010.11.05) or the 8.1D (2010.12.22) Hot Fix should be inspected and necessary adjustments made in Adagio Inventory.
#28358 - 08/11/11 01:37 PM Re: OE 8.1D (2011.03.16) Credit notes issue [Re: Fong]
Hi, Fong,
Perhaps you would provide more detail as to exactly how the credit note is being created. Was it applied directly to a particular invoice or not? Was the quantity being credited the same as what was shipped? Does this item use Alternate units?
#28359 - 08/11/11 02:15 PM Re: OE 8.1D (2011.03.16) Credit notes issue [Re: Softrak Support]
Fong Offline
Adagio Ace
Issuing a credit note against a previous invoice and returning a different quantity of items to inventory than were on the original invoice, an incorrect extended cost for the items was calculated.
Yes Item use alternate units.
#28365 - 08/11/11 08:04 PM Re: OE 8.1D (2011.03.16) Credit notes issue [Re: Fong]
Hi Fong,
We are using 8.1D (11.03.16) and I looked up a Credit Note that we issued yesterday. The credit note was for 1 item from a previous Invoice where 6 of the item was purchased. The Credit calculated the cost correctly, for 1 item. I checked our Inventory account in Ledger as well and it is also correct. I tried a new credit and when I changed the quantity, the extended cost also changed to the new correct amount for that quantity.
#28369 - 08/12/11 07:34 AM Re: OE 8.1D (2011.03.16) Credit notes issue [Re: SusanTennier]
If the item uses alternate units, and the units returned differ from the units sold, then the extended cost has to be adjusted. This is a different (and known) problem than the one corrected in this Service Pack. It has been discussed elsewhere on the forum.
#28373 - 08/12/11 08:06 AM Re: OE 8.1D (2011.03.16) Credit notes issue [Re: Retired_Guy]
Fong Offline
Adagio Ace
Thank you all for replying. This problem happened before(in 2010) and it was fixed. I am sure it will be fixed again.
#28986 - 09/21/11 02:50 PM Re: OE 8.1D (2011.03.16) Credit notes issue [Re: Fong]
Fong Offline
Adagio Ace
Will we have a hot fix soon?
