#26872 - 04/08/11 11:04 AM Emailing PO Document in POA Module
Mavis Dai Offline
Loc: Burnaby, BC Canada
We tried to email PO to our vendor, but it showed error message: An error occurred while attempting to fax document 003323 after we click OK for for Send email screen. Is this error related the program or our set up?
Mavis
#26876 - 04/08/11 12:16 PM Re: Emailing PO Document in POA Module [Re: Mavis Dai]
Hi Mavis,
Checking with the current shipping version of Purchase Orders, I was able to successfully send and receive an emailed purchase order. So the problem is likely with your setup, but I can't say that with 100% certainty. You probably should be in contact with your Adagio consultant to futher determine the cause.
Check that the settings in the Email Setup are correct (whether you use the MAPI or Direct method of sending emails).
What happens if you open the Email Setup and click the 'Test Email' button?
Try sending the email to the Queue rather than Now, to see if a different route has differing results.
It's interesting that your error indicated a Fax error when you were trying to email.
#26882 - 04/08/11 02:32 PM Re: Emailing PO Document in POA Module [Re: Softrak Support]
Mavis Dai Offline
Thank you very much. Now I can email with no problem.
Mavis
0 registered (), 70 Guests and 2 Spiders online.
14599 Topics
