#26629 - 03/21/11 01:59 PM Formulas
Reen Offline
Adagio Groupie
Loc: Saskatchewan, Canada
I am fairly new at using Crystal Reports with Adagio and have been trying to create a formula that when the field has a "zero" qty it will return a - (dash)instead of a 0 otherwise it returns the value but have been unsuccessful. This is the formula I tried ...
IF {ICW65 Items.Qty on sales order} = 0 THEN "-" ELSE {ICW65 Items.Qty on sales order}
Can anyone tell me what I am doing wrong.
#26630 - 03/21/11 02:10 PM Re: Formulas [Re: Reen]
Reen Offline
Adagio Groupie
Also I do not want to just surpress the zeros.
#26631 - 03/21/11 02:38 PM Re: Formulas [Re: Reen]
Hi Reen,
Crystal Reports wants both the 'True' and 'False' results to have the same data type. In your example, the 'True' result is a character, but the 'False' result is a number. This is an error as far as Crystal Reports is concerned.
There is a way to do this without even having to create a formula field. Assuming you have the 'Qty on Sales Order' field already in your report, right-click on it and pick 'Format Field' from the pop-up menu. From the Number tab, click the Customize button below all the pre-defined number formats.
On this 'Custom style' screen at the bottom right side, there is a selection for 'Show zero values as', and a dash is one of the available choices. Pick this and click OK to save it. Now when you print the report, zeroes are replaced by dashes.
#26632 - 03/21/11 02:52 PM Re: Formulas [Re: Softrak Support]
Reen Offline
Adagio Groupie
Thank you. I had been through the format field section but missed the setting for zeros.
Much appreciated.
0 registered (), 136 Guests and 2 Spiders online.
14667 Topics
