#25797 - 01/14/11 01:10 PM Re: RE: ADAGIO FIELDS & TABLE RELATIONSHIPS [Re: Bruce Gardner]
Before creating links between these two tables, first delete any links that already exist.
I don't believe that using OE81C would be the cause of this error.
#25811 - 01/17/11 06:41 AM Re: RE: ADAGIO FIELDS & TABLE RELATIONSHIPS [Re: Bruce Gardner]
Reen Offline
Adagio Groupie
Loc: Saskatchewan, Canada
I think I finally have the links working now.
Here is what I need to see on the report:
**Shipment Date (Shipment Date field & Expected Ship Date fields - both are needed)
**Drop Code (we have used the TaxExempt1 field to put in a Drop Code - which is the order in which the load will be delivered)
**CustomerNumber/CustomerName/CustomerPhoneNumber (I created a formula to combine all of these into one drop)
**Terms (Terms Code field)
**For each Territory (we have 12 in total) I need to have them broke out by territory - the ones that are not working are those with subsidiary Ship-tos where it will not pick up if the ship-to is different than the mailing/billing address ship-to.
**I also need a formula to calculate the total number of orders & invoices for each customer so we know how many picks would be put onto the truck for each. I am having trouble getting this to work as well.
Like Bruse said it is only picking up from the header information. Is there some other field that I should be bringing in to get this to work? Any suggestions anyone?
Edited by Reen (01/17/11 06:42 AM)
#25817 - 01/17/11 11:24 AM Re: RE: ADAGIO FIELDS & TABLE RELATIONSHIPS [Re: Reen]
Hi Laureen,
"**For each Territory (we have 12 in total) I need to have them broke out by territory - the ones that are not working are those with subsidiary Ship-tos where it will not pick up if the ship-to is different than the mailing/billing address ship-to."
If you got the report links to work, then the correct Territory should print. The field could come from one of three places (1 - OE Sale order header, 2 - AR customer master, or 3 - AR Customer contact/ship-to), so make sure that you have inserted the correct field.
"**I also need a formula to calculate the total number of orders & invoices for each customer so we know how many picks would be put onto the truck for each. I am having trouble getting this to work as well."
Assuming that you are grouping your report by customer, you could use a Running Total field object to 'Count' the number of documents (records).
It may be that to get final solutions for your report questions, you might need to get personal support from your Adagio consultant (who can see and work with your report and data).
1 registered (1 invisible), 78 Guests and 1 Spider online.
1865 Members
14510 Topics
27 28 29 30 31
