#22686 - 06/10/10 05:37 PM Re: Terminal services [Re: JohnK]
JohnK Offline
Copied the file into the folder and reran Chksys
Same result!
Odd...
#22687 - 06/10/10 05:47 PM Re: Terminal services [Re: Retired_Guy]
JohnK Offline
The Advantage Database Server is I think one of the core layers of the DB back end is it not?
I seem to recall a little bit ago that one of the fixes was to edit the file ADS... and enter some flag which I also found in the Advantage Database Server help.
So, my guess is that your dev guys are using a local copy of the server and I was thinking that maybe their is a collision with the local server and the 64 bit version of the database engine...
Geek geek geek...
Cheers, JK
#22690 - 06/10/10 07:07 PM Re: Terminal services [Re: JohnK]
"Advantage" is a Sage product. We don't use anything with that name. We're Adagio, and "ADS" stands for Adagio Data Source.
#22691 - 06/11/10 03:49 AM Re: Terminal services [Re: JohnK]
Google says that "Advantage Database Server" is from Sybase. It's definitely not related to Adagio. But it may also be unrelated to the problem.
Chksys can find the file, but is looking for a newer version. Check the properties of that file.
#22693 - 06/11/10 05:08 AM Re: Terminal services [Re: Bruce Gardner]
JohnK Offline
Good morning gents!
Advantage Database server is from Sybase - they bought it from Extended Systems.
Andrew - thank you for straightening that one out - so my problems could therefore not have anything to do with the Advantage Database server - rats - I was hoping I was onto something.
Bruce - thank you for the follow up on the file - I checked the version of the file and it is exactly the one I copied to the system32 folder. I have just rebooted the server and reran ChkSys and it reports the same thing.
The servers we are running are 64bit so, all these modules are running 64bit...
Cheers, JK
1 registered (Samuel Kopstick), 198 Guests and 0 Spiders online.
14538 Topics
