#19181 - 10/21/09 03:05 PM
POA
Loc: Burnaby, BC Canada
Our purchase order number has auto numbering option for 6 digit. Our current purchase number only has 4 digit for now. However, when we print the purchase number, it shows two zeros in front (for example, showing 003093 instead of 3093). Is anyway we can set up for not showing those zeros?
Mavis
#19184 - 10/21/09 05:59 PM
Re: POA
[Re: Mavis Dai]
Hello Mavis:
Are you just interested in how it looks on the P/O when you print the form?
If so, the design of the printed form can be modified to show fewer digits. This is done under Maintain -> Specifications.
However you should know that the form designer tool is different from the other Adagio modules. It is more difficult to use. If you plan to make the change yourself, be certain to do a backup in advance.
#19396 - 11/05/09 09:53 AM
Re: POA
[Re: Brian Stief]
Hello guys,
I have tried to change the display format in the specification. But it only shows the telephone, time and other format without the number format. So how should I create a mask to report only a 4 digit code?
Thanks for all your support,
Mavis
#19413 - 11/05/09 02:12 PM
Re: POA
[Re: Mavis Dai]
Hi Mavis:
Try this: -Right-justify the P/O number field -Use the mouse to make the field narrower (by dragging the "handles")
It may take a couple of tris but you should be able to display only the number of digits that you want.
#19418 - 11/05/09 02:58 PM
Re: POA
[Re: Bruce Gardner]
The mask is working perfect.
Thanks a lot,
Mavis
0 registered (),
349
Guests and
Spiders online. |
14659 Topics
