#16755 - 04/13/09 01:13 PM SalesAnalysis-Print Item Summary MTD/YTD Sales
Mavis Dai Offline
Loc: Burnaby, BC Canada
When I was trying to print Item Summary MTD/YTD Sales, it did not come up with anything. We converted our data from Accpac Plus to Adagio in May 2008. What is the problem for it?
Mavis
#16756 - 04/13/09 03:35 PM Re: SalesAnalysis-Print Item Summary MTD/YTD Sales [Re: Mavis Dai]
Hi Mavis
I'm going to tell you a secret (but don't tell anyone at Softrak that I told you).
The reports that are available in SalesAnalysis under Reports | Standard Reports are not designed to be used, other than with sample data. You can and should ignore them.
All useful reports in SalesAnalysis are to be found under Inquiries | Online Inquiry. The fact that they are called inquiries is a misnomer, they are really reports.
If you don't already know how to create your own inquiries, then you must learn how in order to fully use the program. You can take a look at the 20 or so samples, but it is unlikely they will give you exactly what you need.
However, it takes so little time to create an inquiry (once you learn how) that you shouldn't have to rely on the built-in ones.
#16757 - 04/13/09 04:19 PM Re: SalesAnalysis-Print Item Summary MTD/YTD Sales [Re: Steve Schwartz]
Mavis Dai Offline
Hi Steve,
Thanks for sharing your secret with me:). I will play around those inquiries first to see if I can get it. If I don't, I will ask for more secrets.
Thanks a lot,
Mavis
#16758 - 04/13/09 04:26 PM Re: SalesAnalysis-Print Item Summary MTD/YTD Sales [Re: Mavis Dai]
Hi Mavis,
Why not watch the webinar and learn even more secrets?
Happy Easter!
0 registered (), 225 Guests and 1 Spider online.
14666 Topics
