Previous Thread
Next Thread
Print Thread
#16628 04/03/09 08:42 PM
H
HZN
Offline
H Offline
I'm trying to filter to hide the rolls if the cells on column "OELine Item#" are zero. It didn't work using...
IF({OELine Item#}=0,"","")
Your help most appreciated. Thank you!
If you are creating a filter, all you need is:
{amount field} <> 0
You don't need an IF formula, as that is implied within filters. Note that you are comparing the amount, not the item number itself. Or do you actually want to filter out an item number code equal to zero?
If you are creating a calculated column and you want to only print the value if it is non-zero, then you can do this:
IF({amount field}<>0,STRING({amount field},2),"")
This will output a blank instead of a zero.
If you want to see only the items, not miscellaneous or comment or instruction lines, you can use
{Line Type}="R"
Kate Spontak
New Jersey, the Garden State
H
HZN
Offline
H Offline
Thanks Softrak Tech Support for the quick reply.
And also thank you, Kate Spontak. The one you gave me is what I wanted.
Have a great weekend!!!
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
0 members (), 136 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,625
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
