Previous Thread
Next Thread
Print Thread
#15165 11/19/08 11:25 PM
B
Adagio Fan
Adagio Fan
B Offline
On my income statement, I have a column called "Current Year to Date" and my comparative column for the prior year is for the full year, not the comparable period. ie if the first column is "Six months to June 30th", the comparative column for the prior year would be for the "12 months to December 31st". My problem is in finding a formula for the date of the prior year end that will not change every time I select a different period. How do I "lock in" that Dec 31, 2007 date?
Hi Barry,
If you want the entire previous year as a column on a financial statement, you can use the LY code to see this. LYY is the 'last year, year to date' code that you may currently have.
The formula =GLFPE(code) will output the end of the period, based on the code above. So =GLFPE("LY") will output Dec 31, 2007 (in whatever date format you have defined in the View / Customize / Settings screen and the 'ColSpec date format'). There are other was to format dates, using the DateString formula.
If you want to see what each of the spec codes represent, including the respective start and end dates, you can use the same specification 'GL!SuperSpec90' to see every available spec code, the date range based on the selected fiscal period and year, and the amounts based on your live data and whichever account you choose.
For Adagio FX users, a similar sample spec 'AF!SuperSpec' is available to see the same field layout and results.
Moderated by  Softrak Support
Link Copied to Clipboard
Who's Online Now
2 members (Softrak Support, 1 invisible), 74 guests, and 3 robots.
Forum Statistics
Forums5
Topics14,679
Posts71,631
Members1,874
Most Online1,408
Dec 9th, 2025
S M T W T F S
1 2 3 4 5 6 7
29 30
