#14569 - 09/30/08 09:52 AM
errors
Loc: CRANBROOK, BC
Good Morning I am still recieving critical errors
Critical Error : [1011} insufficient rights to create in data directory
When pressing F6 to look up customers in invoices or receivables, we also get the same msg when looking up vendors in payables.
Another Error msg is when trying to print a posting journal in payables
Error: 120 Lookup item not found. Formulas :Name : =HeaderFooterDateFormat
And posting journals will not print at all
I have don’t integrity checks in all of the modules If I remove the following files the program seems to run ok for a period of time but always reverts back to the same errors QIF002’I.WIL
ARF001’R.WIL
ARF002’I.WIL
APF002’I.WIL
QIF001’I.WIL
I had a tech in, who re-installed adagio, checked to make sure all the rights were set etc. We are running Novel, is there some setting in that which may be causing these prolems?
#14572 - 09/30/08 10:37 AM
Re: errors
[Re: AngelaF]
Hi, Angela,
What versions of Receivables, Payables and Invoices are you using (along with the release dates)? This information is available when you select Help | About from within each module.
When you say you don't have integrity checks in all of the modules, do you mean that, when you access the File menu, the Data Integrity Check menu pick is greyed out? If so, then you need to ask your Adagio system administrator to grant you access or perform the DICs.
With Novell, you need to ensure you are running the latest service packs. Also, ensure that Opportunistic Locking, File Commit and File Caching are turned off.
An error 120 lookup usually refers to having mismatched report tables. For this we'll need to know the versions(release dates) of the modules you are running.
Regards, Softrak Tech Support
#14574 - 09/30/08 02:38 PM
Re: errors
[Re: Softrak Support]
Loc: CRANBROOK, BC
re: the intefrity checks what I ment to say was that I have performed checks in each module and they come out without any erros.
Adagio Invoices, Receivables and Payables are all 8.1A, not sure where I would find the release dates...
#14576 - 09/30/08 03:16 PM
Re: errors
Loc: CRANBROOK, BC
Invoice (070921) Receivables (070920) Payables (070919) Ledger 9.1 (080307)
#14578 - 09/30/08 04:03 PM
Re: errors
Loc: CRANBROOK, BC
i Do not see the following files QRTAPZ80.QRW 3/28/2007.....(I do have a QRTAPZ68.QRW) QRTAPW81.QRW 4/20/2007 and QRTAPZ81.QRW 3/28/2007.
#14580 - 09/30/08 04:53 PM
Re: errors
Loc: CRANBROOK, BC
I had a tech in the office the other day who said he re-installed all the modules, but I will phone him and verfy that.
0 registered (),
169
Guests and
2
Spiders online. |
14599 Topics
