#13965 - 08/12/08 09:21 AM Sign on error
CPS Offline
Loc: Antigua & Barbuda
I am having a problem using the F6 function key in AR. The F5 key works, however. I tried investigating the problem by opening the sample file and got an error message "caution signon failure". I am using the SYS user name and password.
When I created a new file, I could open this and could use the F6 key.
I therefore have two problems.
F6 not working in my AR program
Caution signon error when trying to open the sample file.
#13966 - 08/12/08 09:32 AM Re: Sign on error [Re: CPS]
Hello CPS,
What happens when you press F6 in your data? Are you using SYS/SYS or SYS and a changed password in the sample data?
#14041 - 08/18/08 12:54 PM Re: Sign on error [Re: Retired_Guy]
CPS Offline
The system freezes and I have to shut it down. I am using SYS SYS.
#14044 - 08/18/08 01:55 PM Re: Sign on error [Re: CPS]
Hello CPS,
Is "SYS" the password for the SYS user? "Signon failed" normally means that the user name and/or password are incorrect.
#14152 - 08/26/08 08:08 AM Re: Sign on error [Re: Retired_Guy]
CPS Offline
Any thought process to why the F6 does not work, when F5 works.
#14155 - 08/26/08 01:25 PM Re: Sign on error [Re: CPS]
This post might have the answer.
0 registered (), 150 Guests and 3 Spiders online.
14676 Topics
