Posts: 29 |
I have been trying to update our adagio ledger from 8.08 to 9.0A, I was able to update all of our other modules however when I try to do the ledger I recieve a message saying, Conversion Failed. Error occured when checking the exitance of the GL fiscal years datafile. I cannot find anything in any of the books I have to correct this.
Thank you Angela
Posts: 11,746 |
Hi Angela,
An error like this sounds like one or more data files for the Adagio Ledger are missing or corrupted. Do you know if the data passes an integrity check in the older 8.0x version, prior to the conversion?
Regards, Softrak Tech Support
Posts: 29 |
Hi, I did integrity checks in all of our modules, invoices,receivables,payables, and ledger, they all completed with no errors
Posts: 29 |
Posts: 301 |
Hi Angela - This has happened to me on a couple of occasions. If you have a backup of the Ledger prior to the attempted conversion, restore the file to a temporary folder to make sure the data is the correct dataset. Then delete the GL*.* files in your current data folder and copy the GL files only from the temp folder where you extracted your last backup. Once youhave done this, attempt the conversion again. You will have to do this for both your companies.
I would be curious from Softrak's tech team if this would be the normal procedure and what would cause this ews error. I know the above procedure has worked for me.
Lars Glimhagen
Posts: 29 |
I will try that thank you, i recieved your msg on my voicemail but i didnt get phone number so i was unable too return your call.
Posts: 301 |
Hi Angela - Let me know how this works out. Sorry about yesterday - our office was closed for a staff event. Our number is 1-866-503-1140. Shelagh will be back this afternoon.
Regards, Lars
Adagio Groupie
Adagio Groupie
Posts: 16 |
I'm having the same problem. I've attempted the conversion numerous times, with the same result. I can open the data in 8.1A, and DIC is clean.
Monique
Monique Seys Winnipeg, MB Canada
Posts: 10,504 |
Hi Monique,
Could you e-mail me the database? We'd like to see the files.
Posts: 29 |
So did anybody have any luck with solving this problem?, I did what you told me try Lars, and it did not make a difference. Also we have several computers on our network so I tried updating it on another computer and i received an error MSG saying that my the new ledger was not compatible with the version installed on this computer......
0 members (),
77
guests, and
robots. |
Forums5
Topics14,679
Posts71,625
Members1,874
S |
M |
T |
W |
T |
F |
S |
