#10471 - 12/06/07 02:13 PM Find Function in OE
Acrylon Offline
In Order Entry there is a find function while viewing the list of orders. This function has recently lost one of its options we use to have, and we would like it back. When I press the find button a box pops up labeled "Find". In the leftmost dropdown box are all the categories we can search to find the order we are looking for. The thing that has changed is that one of those categories is no longer there for some users.
Does anyone know how to get this category back into the dropdown box?
Thanks!
Cam
#10473 - 12/06/07 02:18 PM Re: Find Function in OE [Re: Acrylon]
Acrylon Offline
One more thing - what I forgot to mention is that the problem is not in the first "Find" box that comes up. When I double click the white area where the order number should be, another box appears titled "Orders". It is in this box on the leftmost dropdown menu that one of the categories has dissappeared from.
Thanks!
#10475 - 12/06/07 02:29 PM Re: Find Function in OE [Re: Acrylon]
Hi, Acrylon,
I believer you're referring to the SmartFinder window. What category are you referring to? Are you able to use the Column Editor?
If so, double click on the column headings. On the Column Editor window that displays, scroll down the left side and find the field for the 'missing' information. Highlight the field and use the right arrow button to move it to the right side or the selected fields box. You can also the field on the right side and use the up and down arrows to position it in the order you wish to see it in.
It is also possible to 'Set this view for all users'.
#10478 - 12/06/07 03:12 PM Re: Find Function in OE [Re: Softrak Support]
Acrylon Offline
Worked great, thanks!
1 registered (Bruce Gardner), 263 Guests and 3 Spiders online.
14666 Topics
