Hello Fanny,
Have you considered installing and using Adagio's multi-currency module? It automates all the currency calculations for you, but it does require slightly more data entry with every transaction.
Otherwise, you can make a single adjusting journal entry in Ledger, or perhaps more simply, just multiply the amounts in the financial statement by an appropriate exchange rate to get the Canadian dollar amount (not entirely accurate, but the difference is not likely to be material). You can see an example of this by looking at the sample specification "GL!Currency Conversion examples.SAM" in the sample data.
You should check with your Adagio Consultant Reseller for the best method of handling your particular requirements.
