Hi Dwaine,
As Andrew is indicating, with respect to billing, in the AR customer setup, the salesperson default on the "Contacts/Shipto" tab overrides the salesperson default setup on the "Invoicing tab - so that's most likely where the oversight is. Either put the desired salesperson there or remove the code altogether and the system will revert to using the Invoicing tab's default.
Regards, Pete
Peter Banfield
BAMPH Consulting Services
Barbados
