The client wants to bill from Order Entry at a rate of 2.7 for each US dollar. However, they want the price that is going over to AR and the Ledger to be at a rate of 2.6882.
At first as per their initial explanation to me was that they wanted to bill all their EC clients at a rate of 2.7 instead of the usual 2.6882 which is what is being used in other modules as well as the ledger, so of course the only modules this could be accomplished with is OE and AR.
I created a special rate in Multi-currency to facilitate this and change the control account set to reflect this and the invoices were being converted at a rate of 2.7 and the US value that went to the ledger is at 2.7. However now the client is stating that they don't want invoices going to AR and the ledger at a rate of 2.7 but at it's usual rate of 2.6882., but still want the invoice to reflect a rate of 2.7.
I tried to explain the the client that this is not possible, the sub-ledgers would be in accurate and once the bill is done there is no way to change the figures unless done manually, but this would mean that AR doesn't match OE with the audit lists amounts and the Ledger would not match Order Entry figures as well.
Still he insists that this can be done so I am asking to cover all the angles, as I agree with Pete's response about the integrity of the data.
