Working on a P4 3.2 Ghz, 1 Gb RAM, 1 GigaBit Network Connection, XP Pro SP2. DataCare History had 326 runs listed.
I tried deleting a bunch of old runs and thought the PC had hung. I later realised that it's taking over a minute just to delete one run. Makes no difference whether the Backup file referenced in the run exists or not.
No AV scan or anything else running. PC running fine with other Adagio and other Program functions.
This should be quicker shouldn't it.
Regards, Peter
BTW - At this site we had stop the DC Job emailing as it was causing the PC to freeze overnight. Tried a few things but in the end turning off the DC emailing solved the problem. I can't really spend any more time on that at present, but just wanted to alert you in case you had had other reports of this.
